Guest viewing is limited
Discuss Fitting Heavy Shower Tray in recess. Any Ideas ?? in the UK Tiling Forum area at TilersForums.com.
E
easyt
I moved one of the steels thats gone into my new roof on my own, it wasnt masive but 6 metres long and about 180kg. One piece of steel tubing and 25mm diameter in the midle of it and it was a doddle
Yes I decided To roll the base up to the plinth onto a bed of weak sand and cement mortar but resting it on two copper pipes. That will let me manoeuvre it left and right slightly. Then I crouch like a sumo wrestler - elbows locked on knees - Grasp the two glass lifters on the base and raise the 60 kg enough for OH to pull out the pipes. :thumbsup:
495
1,118
Somerset
If tray is in a blind recess, get some of that plastic tape used to secure packages (probably used to secure cardboard around your shower cubicle panels). Use a batten at front of recess, with plastic tape around bottom of tray. Stand tray in verticle on batten (wont damage tray surface) and using tape (you need help and stout gloves) lower tray backwards slowly.
Once tray is lowered back in place pull out tape, and check levels - some jiggling of tray will cause any unevenness in mortar to level up. Some additional mortar may need to be trowelled under fromt of tray.
My plumber taught me this - seems to work well in most situations.
H
heavytrevy
If you have a few mates that are into working on cars like i do , borrow an engine crane assemble it in the bathroom.
use some packing strap around the base lifted it and wheeled it into postion and slowly lowered it onto the mortar bed.
A very easy 1 man operation.
didnt bother pulling the packing strap out , i just cut it flush with the top of the pan when the bed is dry.
Regards
joe bloggs
My ensuite had a hole directly over the shower tray for the fan/light. I secured a block and tackle through the hole and attached same to the tray whilst on a workmate with strong webbing. Took away workmate, laid mortar, lowered tray, cut straps.
I have another to do next month, will do the same. probably best if there is access to room above, but screw hooks into ceiling joists would work.
joe-bloggs-albums-j-bloggs-ensuite-picture9550-shower-pump-tray-some-studwork-place.jpg
joe-bloggs-albums-j-bloggs-ensuite-picture5916-manoeuvring-shower-tray-into-corner-onto.jpg
Reply to Fitting Heavy Shower Tray in recess. Any Ideas ?? in the UK Tiling Forum area at TilersForums.com
I am planning to upgrade my en-suit room 1.5 m x 1.6 m. Ripping out old shower unit and the wall...
8K
As per the title, I have a 1170 recess and the customer wants me to replace the shower and...
8K
Rizzle from the Portizzle
Trying to put right a shower that was badly tiled by someone else. There was a lip on the edge...
Hi I have put a couple of posts previously asking about shower trays and thank you everyone...
10K
charlie1
