Fitting your own air con unit? Discussion ThreadFitting your own air con unit? Electrical Advice
I have a large gym in the garden and it gets ridiculously hot in the summer.
I have utilised pretty much every inch of space and do not want to put a plug in air con unit that sits on the floor as it would just be in the way.
What puts me off a wall unit is the fact you have to get an F-gas registered engineer to fit and these guys are quite expensive. I would like to do it myself.
I have seen this unit Buy electriQ Easy-Fit 12000 BTU A++ WiFi Smart Wall-Mounted Split Air Conditioner with Heat Pump and 4.5-Meter Pipe Kit from Aircon Direct - https://www.aircondirect.co.uk/p/865335/1000-btu-panasonic-powered-easy-fit-inverter-wall-split-air-conditioner-with-5-meters-pipe-kit-and-5-years-warranty
which states it does not need an F-gas engineer to install.
Does anyone have any experience with these units? Are they equally as good as the ones that contain fluorinated gases?
Any other clever ideas?
Fitting your own air con unit? for the original thread on Electricians Forums
