Discuss Fixing 10mm Marmox Boards in the UK Tiling Forum area at TilersForums.com.
siremastimus
After reading through the forum have bought some 10mm Marmox Backer Boards, plastic Marmox washers, Marmox sealant and Mapei Keraquick to fix with.
I understand I also have to secure with screws and raw plugs. Can anyone recommend the best type of screw to avoid rust etc?
When fixing the boards do I dot and dab with the adhesive and fix, let dry and then screw or as I think I have read elsewhere should I fix the screws whilst the adhesive is still wet and fix the screws actually through the dots on the board or just space our at regular interavals (board is 1200 x 600)? Thanks
in my opinion and experience the 10mm board is too thin to dot and dab to a solid wall.
I would recommend a 20mm board as a minimum.
use 6 good size dabs per board over pre drilled locations
use sealer on the joints (tube)
use stainless screws and washers or spankers
tape all joints
Gazebo
as spanish says in his opinion 10mm is too thin but Marmox say you can use 10mm thats why I said use some extra dabs of adhesive and more screws. make sure there is adhesive around the perimeter of each board, if the wall is good enough then you can practically tile the board to the wall with a thick bed of addy. then fix with screws....
Reply to Fixing 10mm Marmox Boards in the UK Tiling Forum area at TilersForums.com
    • Friendly
I'm having a nightmare trying to establish product info from distributors. For example...
    Votes: 6 4.6%
    Votes: 11 8.5%
    Votes: 8 6.2%
    Votes: 37 28.5%
    Votes: 16 12.3%
    Votes: 31 23.8%
    Votes: 3 2.3%
    Votes: 2 1.5%
    Votes: 19 14.6%
    Votes: 18 13.8%
    Votes: 15 11.5%
    Votes: 7 5.4%
    Votes: 3 2.3%
    Votes: 2 1.5%
