Discuss Fixing 1500 X 750x 10mm Porcelain To Large Floor Area in the Australia Tiling Forum area at TilersForums.com.
jonnyc
got a decent sized floor to start next week . approx. 220 sq mts .
will be laying ditra mat.
I usually use tilemaster setaflex for all porcelain and stone but feel that these bigger pieces may need a pourable thickbed adhesive. any recommendations ?
alo ned to buy a dry cutter that will go up to 1500 mm. any good cutters that will snap a 1500mm length @ 10mm.
wont do many jobs of this size so is therea glass cutter that would do the job.
marazzi whi are supplying the tiles suggest using lash clips but what do you reckon.
I think they put undue strain on a tile
widler
1,328
England
Id use setaflex jonny, and lash clips, on those size and weight id use raymondi , cracking clips and big .
If your not using seta id use tm ultimate , sticks and sets like the preverbal mate ;)
Cutter not sure about, i have a glass cutter which ray at porcelthin sent me, cut the porcelthin fine, not sure about 10mm tiles though
Simons70
763
Luton
We start today to fix 1800x800 x 10 mm,fix with tilemaster setaflex,cut with this tools. 20150630_090754.jpg 20150701_191316.jpg
Rizzle from the Portizzle
i used the same cutter to cut 1200 x 1200 14mm grade 5 porc polished scribed put a pencil under each end then a big push cut no problem and cut plenty of polished pocrs no problem.but if small peices you will need a breaker to start the break the small wheel gives a much better frature line and cleaner cut
jonnyc
I bought a glass cutter from Ray and gary the tiler kindly delivered to me yesterday.still undecided. I've got seta flex to fix ditra and might try fixing a tile with that and see how it goes.
widler
1,328
England
Jonny, you know your stuff, you lay stone like i lay the wife, weekly (dan DO NOT TELL THE WIFE I SAID THAT) so weight of tiles shouldnt worry you :)
I laid 800x800 porcal last week, bloody heavy , i used lash now and again to hold the tiles, i do think they are great things on large format:)
Ultimate is the dogs mate ,if u are unsure about seta, ultimate is good good stuff
Ps
Im a bit drunk.
it realy is a good cutter all you have to do is what you all ways do .listen to the scribe to know how well its done its job
Reply to Fixing 1500 X 750x 10mm Porcelain To Large Floor Area in the Australia Tiling Forum area at TilersForums.com
Hi All, I urgently need some advice and not sure where to turn. We are having some major...
6K
Rookery
I'm fixing about 90 metres of 10mm 800x800 porcelain tiles at the moment, using a Rubi Tx 1200...
19K
Unused Account 1
U
Hi all, got a 70sqr mtr floor to do in tumbled limestone in sizes 1000mmx600 900x600 800x600...
17K
K
Apologies if this has been covered but I could not find much info on aquapanel searching...
12K
Unused Account 1
U
Hi Guys Im new to this forum and am based in sunny South Africa. My knowledge on tiling isn't...
5K
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
