Fixing glass mosaic tiles behind wall mounted wc
opticsman
I am fitting a wall mounted wc and want to use 20mm square glass mosaic tiles (OriginalStyle) between the porcelain bowl and the wall. As these tiles are very fragile I believe I need to use some form of offset spacer. The bearing surface of the bowl (apart from where the fixing bolts pass through) is in the form of a thin edge rim - can anyone advise any tried and tested techniques?
Try the stick on draught excluder foam type, like you see around doors and windows....this will offer some cushion between surfaces......Gaz
opticsman,
brian c,
opticsman,
brian c,
