Discuss Glass Mosaic adhesive choice and surface preperation in the Tile Adhesive / Grout Advice area at TilersForums.com.
Hi guys
Find myself a little stuck and in need of some technical advice. I'm about two thirds through tiling a small bathroom with large format ceramic tiles however I have a vertical feature panel of glass mosaic to install and I'm not certain how to proceed.
  • Mosaic are blue glass, transparent, 7mm thick set on 30cm square mesh backing.
  • I've allowed 60.2cm wide space above the bath for these to be set into 2 sheets per row and about 2.2m tall.
  • Ceramic tiles are about 8/9mm thick, finished surface is about 12-13mm including adhesive.
  • Walls are flat having been dot, dabbed, screw fixed with Orbry boards.
  • There is a over bath shower so the mosaics will be subjected to overspray.
Despite reading through other posts I still have a few questions which I hope you wise folks could help with...I'd really rather not screw it up.
  • Adhesive recommendation? Ideally available in small quantities retail bearing in mind I only have approximately 1.5m2 to cover.
  • Trowel choice and bed thickness? I've read elsewhere 4mm square vs 3mm V knotched trowel depending upon the tile, these are about 7mm thick.
  • Should I use mosaic mesh sheets to aid installation? I was wondering if these reduce adhesive contact with the back of the tiles.
  • If I do use mosaic mesh what effect will this have on trowel size/bed thickness?
  • Lastly is there any recommendations regarding building out the surface to bring the mosaic flush with the adjacent ceramic tile? If necessary I was leaning towards screeding the surface to a specific depth with tile adhesive subject to above recommendations on bed thickness and mesh usage.
So I'm a little unsure how best to move forward really and would be grateful for any help.
Reply to Glass Mosaic adhesive choice and surface preperation in the Tile Adhesive / Grout Advice area at TilersForums.com
  • Question
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully screwed in. The Tiler laid my 5mm hex mosaic tiles on a 2mm bed, so obvs wasn't going to drain. I took...
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Question
