Discuss fixing plaster board in the Canada Tile Advice area at TilersForums.com.
klunk
Hi,
I'm in middle of a bathroom couple walls had come off back to brickwork but only 5 feet high it's very tall ceilings
It's all been decorated recently so I want do as little damage as possible
Question is normally I just dot and Dab boarsds to ceiling with normal drywall adhesive but I'm very tight for depth is the foam in a can for fixing boards strong enough hold a wall of metro tiles ? Or is it just meant for skimming
Dumbo
Hi,
Does it say on the can it is meant for fixing plasterboard
Time's Ran Out
Hi,
Dot and dab boards to ceilings ?
Reply to fixing plaster board in the Canada Tile Advice area at TilersForums.com
    • Friendly
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
Paramount wall fix for tiling ideas? the plan is (or was) to tile floor to ceiling with 200mm x...
The walls are already plastered, I know it’s better if they hadn’t been, can I just mechanically...
    Votes: 9 6.2%
    Votes: 13 9.0%
    Votes: 10 6.9%
    Votes: 44 30.3%
    Votes: 17 11.7%
    Votes: 34 23.4%
    Votes: 3 2.1%
    Votes: 20 13.8%
    Votes: 18 12.4%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
    Votes: 4 2.8%
