Discuss Fixing plasterboard in the Canada Tile Advice area at TilersForums.com.
L
lasors
Hello all,
I've dot and dabbed MR plasterboard to bare block walls. They were skimmed but it was nowhere near flat and would prove difficult to tile with 400mm tiles, so it all came off.
I was wondering if people think it's a good idea to add some mechanical fixings as well, and if so, what kind? And how many per board? So far I'm thinking 60mm hammer fixings, if they can easily be knocked flush and still pull on the board. Tiles are 20kg/sqm.
Any advice?
Jim
L
lasors
Sorry, it was plaster only, bonding coat and skim. Hacked it all off down to the blocks with hammer and bolster, PVA'd for dust stabilization, then dot and dabbed new board to the blocks. Seems solid enough but I'm usually keen on belt and braces approach so was wondering what might be safest method.
If it's agreed the adhesive will be fine on its own then I can live with that.
widler
1,328
England
Plasterers all use diluted PVA for fixing plasterboard so would have thought so. Few frame fixings (self tapping or sleeved depending on the background) can't hurt though. If the background is lightweight blocks use sleeved fixings or plugs.
I just wet em with h2o
Reply to Fixing plasterboard in the Canada Tile Advice area at TilersForums.com
Not sure if this forum is broken I can’t see most posts due to adverts, but I’ll give it a go...
Hi All. I'm installing a new shower enclosure and hoping for some advice on fixing the 12.5mm...
6K
hmtiling
H
Hi guys, I'm looking to start my bathroom renovation with the intention of tiling the whole...
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
Fixing plasterboard
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
