ceekay
Hi Guys
Hoping you could advise.
Firstly tiling the shower area - I have 600 x 600 porcelain tiles for the ensuite floor and I will want the tiler (when I find a good one that does wet rooms in my area) to use them on the shower area which will be 1200x900 and mounted on a marmox tray which only has a very slight built in slope to the trap. Will you guys be able to do that or are most tilers going to suggest using moziacs in the shower area?
Secondly - Will hopefully be having the tiles on the wall running straight down to the floor which avoids ugly skirting but obviously would still need arc around the door and was wondering if this can be replaced with either a type of plastic trim or similar as it seems mad doing away with wood skirting but still having wood arc around the door but obviously you need some sort of finish there.
Lastly - How do you guys go about mounting all the bits and pieces after the tiling is complete for example the shower screen and shelves and mirrors etc without breaking the wetroom seal so to speak.
Hope you can help anyhow so I can stop worrying about all the little bits and if any decent wetroom tilers around the Bury, Lancs area on her please let me know, thanks.
