Guest viewing is limited
Discuss Flexible Adhesive Recommendation in the Canada Tile Advice area at TilersForums.com.
bgatty68
As i am putting hardie backer boards (6mm) on my bathroom floor to tile onto and assuming I would need to use a flexible adhesive-is that correct- can someone recommend one either they have used with backer boards or if they have used on any floor where movement is possible please. Also what about grout for a floor where tiles are laid on backer boards or doesn't that matter:smilewinkgrin:
Reply to Flexible Adhesive Recommendation in the Canada Tile Advice area at TilersForums.com
I'm having a nightmare trying to establish product info from distributors. For example...
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
