Discuss Flexible conduit for Temp Sensor?? in the Australia Tiling Forum area at TilersForums.com.
p4ulo
Bugger it, the shops are shut, and I've just seen that the temp sensor for my electric floor which I planned on installing, taping down and SLC'ing over tonight after work at 1030 "should" be mounted inside a flexible conduit!!!
Any advice.
I've read a few things on the T'internet that says Its not overly necessary as they "extremely rarely" fail.....!?
So, B+Q is open til 9pm....I'll take a mooch and see what I can find....I could use a bit of garden hose I suppose? Any thoughts.
Gutted cos plumber is coming tomorrow evening and I was hoping to get the dirty stuff done before he got there!
Time's Ran Out
The electric mats have guarantees of 10-20 years.
The sensors 1-2 years!!
I'd make sure it was accessible.
We tend to make them 'getable' from the skirting across the floor in a tube. In the wall a draw wire will pull a new cable through. Usually find that the tubes won't pull/push a thin cable at the point of bend.
And on that note - why are they all ribbed on the inside - almost impossible to feed the cable through!
p4ulo
Tech sheet says :
"as the warranty does not cover the floor, it is recommended that the floor sensor is installed into a non-conductive conduit. this will allow for easy replacement of sensor after the flooring has been laid"
Nothing included in the kit!
I've bought a length of 12.5mm bore garden hose, and that's my choice. it was either that or 20mm thick flexible conduit that would've bought the height of the floor higher than everything else!!!
p4ulo
Oh that would work. Do you think its allowed to cut the sensor wire and make a join?
What I'm thinking is - simple tube to centre of the floor, which comes out underneath the remove-able bath panel.....put a connection in it, connect to the rest of the wire then hard-set the rest of the very thin wire in the floor up to the thermostat??
It seems its a very thin 2 core wire so I'm sure a connection would work well???
Rookery
Not all the ufh kits I've fitted over the years have come with a conduit. In those cases I've just encased the probe in the slc I always pour. In any case, it's all very well being able to draw a duff probe out through the conduit but I'm bl@@dy sure I'd never be able to feed a replacement down the conduit right to the end. You could always fit a 2nd probe in case the first one fails.
p4ulo
You cut it at the end being connected to your control unit.
Remember all electrical connections require a Part P certificate from a fully qualified electrician, even in your own home.
Yeah that's cool....all wiring being done by a proper chap.
I just read that the sensor wire can be extended using bell-wire up to 50m....I suppose I could leave all this section of wire under the bath, then route a section of "bell-wire" up to the thermostat.....
Dammit....another case of hoarding being rewarded, I knew I kept that length of bell-wire in the garage for something!!!!!
p4ulo
Could I suggest you pop along to the electricians forum and ask the same question!
I've had a look on loads of places.
Most other suppliers of UFH say "the temperature sensor wires can be shortened or lengthened, just don't cut the wires at the plastic end that contains the sensor" (DUH!)
Oh gosh, I dunno now....what shall I do?
Reply to Flexible conduit for Temp Sensor?? in the Australia Tiling Forum area at TilersForums.com
H
Hi all, I'm new to the forum but very much hoping you can help with a problem I've got.. We had...
11K
Rizzle from the Portizzle
I'm a Plumber by trade but will often do a bit of tiling as part of a bathroom install when...
11K
destroyer2813
Hi there, new to this so bear with me. We have a large walk in wet room built about 10 yrs...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
