Discuss flexible wall adhesive in the British & UK Tiling Forum area at TilersForums.com.
davey-j
hi again, another question of many more:dizzy2:.
I understand the need for flexible floor adhesive and grout as this area gets walked on.My question is ,can anyone explain the need for flexible adhesives and grout on walls.Could you also tell me when it would be best to use this and in what areas.
Many thanks advice appreciated.
doug boardley
to be straight with you Davey-j, what else would you use? most tiles being fixed now are classed as large format ie over 300x 300 mm, so a powdered adhesive is needed for setting purposes. A lot of walls are subject to movement and stress, just like floors, so, imo, it makes sense to use flexible addys to counteract possible movement.
Reply to flexible wall adhesive in the British & UK Tiling Forum area at TilersForums.com
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would...
Hi all, We employed a tiler to lay some rectified wood effect planks in a herringbone pattern…...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
