Discuss Floating floor will you or won't you in the Canada Tile Advice area at TilersForums.com.
baht'at
Hi all.
My first floating floor to tile so seeking advice as read quite a few threads where some will and some won't tile on them.
The work in question is a new extension on a property consisting of 4 rooms 3 of which need tiling in ,with the same tiles in running through all of them.
Kitchen 24sqm
Hall 6.5 Sqm
Cloakroom 4.5 sqm
At the moment this extension is just a block shell with each room sepperated by a single course of blocks which will be the floor level sepperating each area from the next in the door ways.
The customer informed me that the builder will be laying Kingspan and over boarding each room.
(1) My concern with this is should the over boarding run through each door way or stop in the middle of the door way and as there will be block work under the joining point to the next room could there be problems with temperature in these areas.
Originally these floors where to have piped UFH heating but due to gas supply problems for 2 boilers this has had to be changed to electric matting.Which I informed the customer would need covering with SLC even though I have read on here before some don't but I am happier if it is just to protect the cables from the trowel.
I have tiled over UFH before but it has always been a continuous mat and not separate mats.
Each room to be tiled with the UFH will be independently wired and controlled.
(2 ) Would an expansion joint be required between each room as in the door way, as these floors may be operated at different times.
( 3 ). Could antifracture matting be used in the door ways instead of an expansion joint.
Any advice on prep work and the laying of the tiles would be greatly appreciated
baht'at
Thanks for the replies.
As I thought there would be mixed opinions and the NO's lead at the moment.
Just to add to my original post .
There is a concrete base in each room and would probably take at least 100mm of Kingspan plus 20/25mm tounge and groved boards.
Having read on a few "Tiling advise" sites there are some saying as laid on concrete there would be very little if any movement and to over board with 6mm no more ply would make it all more ridged, and as long as the tounge and grove are glued and also the edges of the no more ply are also glued it should be fine for tiling.
Any views?
Chalker
1,058
Tadcaster
If you fit fermacell flooring on top of the insulation. Instead of chipboard / ply . It will be fine. It's a gypsum product, that is glued and screwed together. True it is a floating floor, but it is stable and you can tile straight to it.
The boards are very heavy .
This link explains it.
Jupiter Systems - Fermacell - http://www.noneedtoscreed.com/fermacell.php
Andy Allen
1,318
Gloucester
But What about the thousands of houses with kingspan or jablight under there concrete floors though? Shirley theres much more weight with concrete on top so thinking logically the concrete floor would compress the kingspan more ?
before now ive fastened down the floor with screws etc , hardied and tiled .
I would fill my pants panicking I would hit a water pipe or a lecky cable doing your method...
One Day
That's true, but a thick layer of concrete doesn't sag and bend like chipboard. Plus it fills and dips and gaps.
baht'at
Thought I had posted this earlier hadn't.
Information for any one considering tiling on floating floors .
Have just found out No More Ply now manufacture a flooring board 22mm thick and 2400 x 500 in size with a tounge and grove which would need glueing.
This should be ridged enough for the job and could save time and money as won't need the chip board overboarding and will take UFH mats
baht'at
I have also posted the above information as a new thread just sso it was visible to those who might not have looked at this thread and may not be aware this product was available.
It was suggested yesterday by Chalker that Fermacell products could be suitable in this instance, and it was checking with with local suppliers in Leeds and Bradford for Fermacel's 2E11 boards I was made aware of the No More Ply version.
Having read through the Fermacell "Dry Flooring" installation instructions,unfortunately there is no guidance to tiling over their product.
From their information their system seems to have been designed for use with water based UFH systems as does state not suitable for use with cable UFH systems, but it's not clear if they mean above or below the boards.( another phone call to make )
As most will use the Cement based boards when cable (matting) UFH is installed over wooden floors the No More Ply version does seem a better option .
Reply to Floating floor will you or won't you in the Canada Tile Advice area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a...
