Discuss Floor build up for tiling in the Canada Tile Advice area at TilersForums.com.
Dave Dux
Current plan for floor is 18mm chipboard + 6mm nmp, then 6mm insulation board + durabase Matt with Electra heating cable before tiling with flexible ad. Insulation board and Matt to be installed with flexible adhesive. No screed over cable.
Question, is it worth sticking with the insulation board to improve warm up time?
Spare Tool
answer to 1st question is still no
Agreed wood is an insulator but cement board isnt, no point heating that up, I'd have done away with the nmp and used a 10mm insulation board, but as nmp is already down for what it is might as well insulate before ufh mat..
Boggs
1,118
Uk
Personally I don’t use insulating boards or uncoupling matting when installing UFH on timber floors.
6mm Hardie backer glued and screwed, heating cable, thin skim of levelling compound and tile over.
Heating up time is around 15mins.
Reply to Floor build up for tiling in the Canada Tile Advice area at TilersForums.com
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
