I did have a case a few years ago of floor tiles cracking over a joint in the Hardie backer. In my case it was because of water getting under the Hardie backer and causing a bit of swelling in the floor boards underneath one of the hardie-backer sheets (actually half sheet nearest bathroom door). This sheet lifted slightly relative to the adjacent sheet and so there was a bending in the Hardie layer at the joint which transferred to the tiles and cracked them. In my case I think they were normal floor tiles, so rule everything else out before blaming the tiles in this case.
There are many so called floor tiles which may be suitable for fixing to a floor in an upstairs bathroom (bare feet and slippers only) but also only need to be fixed to a very rigid substrate (more rigid than BS overboarded floor
standards?) and probably need decoupling as a standard.
I think there is a case for floor tiles to be given more relevant grading system which should be clear on the packaging eg. as here suitability for fixing to different substrates; suitability for under tile heating, slip resistance, water resistance, abrasive resistance (hardness), etc. One day!
