Discuss Floor prep.... in the British & UK Tiling Forum area at TilersForums.com.
Mouldy
563
Park Gate
What would you guys do with this before you tiled it? Joists are 5x2, boards are just over 1/2".
18mm ply pver the lot? Have to be carefull that I dont pierce pipework with screws!! :yikes: Unfortunatly theres a lot of it under there, including gas.......
Or would you lift the boards and screw 18mm directly to the joists?
Mouldy
563
Park Gate
Height isnt to much of an issue but obviously I cant go too mad. There was a lot in the room:-
and its all going back, allbeit in different places. Bath and shower positions are swapping and basin going over by rad. Floor has a bounce if I jump on it and Im no heavywieght, (12.5 stone).
Never been overly concerned before but this ones got me thinking a bit! Walls are all over the place, as was the ceiling.
Had to overboard the ceiling due to Artex not being adhered, dubbed out all the high spots and the two coats of multi:-
Right hand wall looked like this:-
:yikes:
Spent three days on the prep so far, two bags of bonding and two bags of multi!
Mouldy
563
Park Gate
Oops, just thought I havent given the full picture....!
Wall with window and to the left of window are outside walls. To the right and immediatly to the left of the door are masonry partiotion walls that are, wait for it, (drum roll please....), sat on the bloody joists! No steel just good ole timber. :yikes:
Mouldy
563
Park Gate
So tell me about this Ditra matting then. I know what it is but Ive never used it. I understand that its a de-coupling membrane but if its adhered to the substrate, how is this decoupled?
Floor joists are 4x2 not 5 as I first thought and there is deflection in the mid part of the floor when its stood on. Never had experience of dealing with a floor this bad!
Reply to Floor prep.... in the British & UK Tiling Forum area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
If starting from joists, what subfloor would you use these days? 18mm Ply first and then a 6mm...
Mouldy
Park Gate
What member type are you?
  1. Bathroom Fitter
Business Name
IDM Bathrooms
Floor prep....
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
