tim_c
I pulled up the old cracked and loose tiles in my conservatory with a view to re-tiling.
Underneath I found a nasty fibreboard tounge and groove type floor, that seem to be about an inch and a half think. It's got all of about 4 nails holding it down that I can see, and movement around the joints in the board caused the previous tiles to fail. There's a gap all round the edge that's siliconed to seal it from the air gap underneath.
It's all dry and rot free, and there's no flex when I walk on it, although if I smack it with the rubber mallet, dust jumps up a suprising distance away.
I may need to screw the board to the frame underneath.. but how do I find the joists?
I also need to overlay the floor... I can spare about 12mm of height. Would ply or backer board be best? Either way, it's going to double the cost as I guess I'll also need a proper flexible adhesive and grout as well.
Anthing else I need to take into consideration?
