Discuss Floor Screeding in the UK Tiling Forum area at TilersForums.com.
MSB Tiling
Took a kitchen floor up yesterday, after taking all the tiles up and adhesive it was clear to see the floor was no near level. (Concrete Floor)
Ive bought some SLC but it gets to a stage where it is 20mm thick going to 40mm thick over a 2.4m length.
Ive got a bit of advice saying that i can use sand and cement to screed that bit.
What i was wondering was what ratio should I use, and im guessing the mix should be quite dry, is this correct?
Thanks MSB Tiling.
Ajax123
1,213
Lincolnshire
I agree with Phil. Sand cement would fall to bits at that depth. You could use SLC with fibres.....some do allow you to bulk them out with silica sand to allow you to use less SLC if cost is a problem whcih I can imagine it is at that sort of depth.
Reply to Floor Screeding in the UK Tiling Forum area at TilersForums.com
Floor Screeding
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
