olly330
Thanks, very helpful, will check tomorrow with tapping to see they are held in well.It's mainly down to the tiler to check the batches and ensure they're all matching, and even then, still work from several boxes at one time (so mix a few boxes up and work from that pile so they're mixed). So well done for getting the shop to take responsibility.
You can lay the tiles over the tiles as long as they've been fixed well using the correct stuff.
Perhaps try and pull one up in the middle and make sure they have 100% coverage.
You can also try tapping them in various places using a pound coin. You will be able to tell where there are voids as the note changes to a high note. If you tap the coin on something solid first like the bricks to your house etc you'll hear a dull sound, that's what the tiles should sound like EVERYWHERE when on floors.
What's the best solution for where they meet the wall tile, should there be a gap and if so should it be filled with grout or clear/black Silicon?
Do you think the height will be too much?
