Discuss Floor tiles coming loose with clean backs in the Best Floor Tiles area at TilersForums.com.
Hi all,
Thought I'd sign up and see if someone can offer me some advice...
I (stupidly) laid some porcelain floor tiles using a non flexible ceramic powered adhesive. A few of these tiles have come lose and when they have the backs of the tiles are clean of adhesive but I can see that they had full contact with the adhesive from the pattern in the floor.
After re-laying one of the tiles with the correct flexible porcelain adhesive the tile once again came loose with a clean back. I've used this same adhesive on wall tiles without a problem so I'm pretty sure the adhesive is good.
I'm trying to work out what the likely causes of this is...
As I only re-laid the one tile I don't believe the adhesive skinned.
The subfloor is original 18mm x 13cm planks which I've laid 6mm hardie backer board on top of using adhesive and screws. Should this be enough to stop movement in the floor?
I can't see any localised movement/deflection in the floor but I asked a friend to jump up and down around the area in question and did feel like there was movement in the bathroom as a whole... Could this be part of the problem?
If the problem was caused by movement would you expect the back of the tile to be clean after it lifted off?
I thought about adding some primer to the back of the tile, is this something you can do and would it help with adhesion?
Any other thoughts or advice?
Cheers,
Dan
Reply to Floor tiles coming loose with clean backs in the Best Floor Tiles area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
https://www.tilersforums.com/threads/tiling-on-mapei-renovation-screed.91864/post-964717 Hi...
Essex
Best Floor Tiles
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
