Discuss Floor tiles have been installed / fixed using tubbed adhesive in the Tile Adhesive and Grout Advice area at TilersForums.com.
Dave
Staff member
Subscribed
389,914
1,000,000
Co.Durham
My tiles are moving after 3 days of been layed on Cement floor. I used MapeGrip D2. just seen a date on the side 9/06/23 what does that mean? I did put the tiles on the same floor about 10+ years ago with ease
D2 is a Dispersion adhesive and not suitable for floor tiling.
Dan
Admin
Staff member
5,084
1,323
Staffordshire, UK
Ooooo unlucky. You found us after you did that!.
Get them up scrape it all off the floor and the tile. Bin that.
Then use a cement based adhesive and mix it in a bucket. You can get 24hr setting ones to give you some extra bucket time.
And your tiles are already cut.
So you were nearly spot on.
Don't suppose it was a shop that let you walk out with floor tiles and wall tile adhesive?
Reply to Floor tiles have been installed / fixed using tubbed adhesive in the Tile Adhesive and Grout Advice area at TilersForums.com
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
Tile Adhesive Trending Topics
