Floor tiles on asphalt, which adhesive/ grout?
i would always use flexi adhesive on any asphalt surface with flexi grout bal spf is a single part flexi you could use a porcelbond adhesive for asphalt
What is the best adhesive to use for ashfelt floor/roof it has had 3 layers of roofing grade ashfelt so 12mm thick
thanks for replies,
asphalt is flooring grade, well cured
there is not enough height to do the sand/cement option
can anyone give more detail on spf? is this BAL spf? or are there any other products I can use, (I assume the Dunlop Set Fast Plus is not spf?)
thanks again
Dont use bal ...I've had nothing but trouble from bal flexi one to the spf .. and now bal say every excuse under the book ..yet 15 years ago I had no problem in other rooms ... put bluntly ..bal = rubbish
Dont use bal dont use bal spf had problems with newer floor bal refuse to say there adhesive is powdery..every excuse yet 15 years plus other floor never had any problems ..fobbed off by there spec sheets and excuses ...
simonrad,
Tiler 15 years plus,
simonrad,
