Discuss Floor tiles under wall tiles??? in the Best Floor Tiles area at TilersForums.com.
Grace'sDad
walls 1st (to the floor ) then ply and tile the floor
wood expands and contracts and"could " put presher on the wall tiles , loosening them in time
Wood expands and contracts laterally WAY more than vertically! If the floor swelled enough to pop off the wall tiles - i think the wall tiles would be the smallest problem:thumbsup:
I always tile walls first, leaving off the bottom row. Tile the floor nice and tight (not too tight, mind!) to the wall and then drop the last row of wall tiles down to the floor (using a 1mm spacer on the floor) and Silicon where the wall meets the floor - thus allowing for slight expansion & contraction
pjtiler
if it works for you bud fine
seems like your making extra work to me
but wot the f£ck do i know
MICK the Tiler
It can be done both ways,but here's something to keep in mind. If the floor tile is laid first and the wall tile comes down over it the floor tile acts like a flashing with the wall tile on top to redirect water away from the joint.
If you lay the walls first then cut the floor to the walls even though it is siliconed the integrity of the joint is compromised and over time water will enter the horizontal joint and move under the floor tiles.
Obviously it isn't critical in open floor areas that don't see a lot of moisture, but in the confines of a shower recess it is critical for the water to be deflected away from the joint.
Here's another example, You wouldn't dream of tiling the walls first then installing a shower tray pushed up to the tiles? then say the Silicon will hide any joint and it should be fine. Water will indeed find its way between the tray and the tile. Your tiling is no different.
Down here the Australian standard states that wall tiles must come over the top of the floor tiles for the very reasons that I state above.
If you are in doubt as to what you think is the correct method you should consult a copy of your local british standards.
H
hasher69
That seems exactly right, most people forget to consider the water factor!!
One of my bathrooms leaks because the tiler butted the floor tiles up to the wall tile !!
H69
Reply to Floor tiles under wall tiles??? in the Best Floor Tiles area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hi all am changing tiles in my kitchen ans expect to damage the walls removing tiles . Think the...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
Best Floor Tiles
    Votes: 5 4.0%
    Votes: 11 8.7%
    Votes: 8 6.3%
    Votes: 36 28.6%
    Votes: 16 12.7%
    Votes: 31 24.6%
    Votes: 3 2.4%
    Votes: 2 1.6%
    Votes: 19 15.1%
    Votes: 18 14.3%
    Votes: 14 11.1%
    Votes: 6 4.8%
    Votes: 3 2.4%
    Votes: 2 1.6%
