Discuss Floor tiling directly onto retrofit wet UFH overboard. in the Canada Tile Advice area at TilersForums.com.
Sandy737
Eg. Cellecta HiDeck 18, Polypipe Overlay, WundaTrade EPS 400
They are designed to go onto existing concrete and can take stone tiles without any screed, or so they claim.
Anyone had experience of floor tiling directly onto these type of boards.
Particularly interested to hear if anyone has any personal experience.
J Sid
that's the one with the aluminum on it i believe.
I know a company which used to sell it but stopped because after testing it found the week point was the bond between the board and aluminum failed.
I also understand you will need to fix tiles with a bottle and bag mix of adhesive.
I have used it once on a small floor, 8m2 and stuck Ditra on top with a two part addy then tiled as normal , no comebacks after 3 years.
I personally wouldn't use it as there are others on the market which I believe are better and safer.
N
NZ_Tiler
I
Hi Julian. Thanks for your reply, much appreciated.:)
So far, these are the only 3 I have found that claim to take stone/ceramic tiles direct.
Cellecta HiDeck 18 £30.00/m2
Polypipe Overlay £22.00/n2
WundaTrade EPS 400 £17.00/m2
Do you know any others?
I had a similar job come up recently.
The manufacturer was john guest speedfit. A tf member on here recommend their gypsum type for tiling direct to.
Tile Shop
I'm still dubious about these systems being safe to tile onto. They make claims that it can be tiled, but you won't find a manufacturer that will guarantee their products on them.
But if you haven't purchased it yet, have a look at the full Wundafloor system. This is the only system I am aware of that has been fully tested by an adhesive manufacturer and deemed suitable for direct tiling. Mapei have done a full spec of adhesive (either Elastorapid, or the Kerabond T with the Isolastic additive) and fixing methods, so if anything was to happen in the future you would at least have somewhere to lay blame. A luxury you wouldn't have with an untested system.
Reply to Floor tiling directly onto retrofit wet UFH overboard. in the Canada Tile Advice area at TilersForums.com
Hi all, I will soon be installing the Wunda EPS 400 UFH boards in my own kitchen, approx 50m2...
Hello, just seeking some much appreciated advice about tiling over a wet ufh system which is...
Hi guys, sorry for the clunky thread title... Just over a year ago we had a side...
Hello everyone, I'm about to lay some antique 6"x6"x 0.5" ceramic tiles, all clean and dry, onto...
Hello friends. I am looking for a bit of advice, you would be so kind. I have been a long...
Tilers Forums on FB
