cityone
Evening lads, i,ve read quite a few debates on here lately about this issue, i,ve got to be honest i,ve always used plywood overlays when tiling floors, i use 15mm marine ply which i screw through the floorboards into the joist and i,ve never had any problem or had to return to any job i,ve done. Now after reading on here about the poor quality of plywood going around i am thinking about changing to cement board, i already know the advantages it has, (better bonding, not the same issues with raising the floor height etc) my question to you is what thickness should i use and what is the minimum thickness i can get away with??? where i live we only really have a jewsons, are the cement boards from them ok?? thanks in advance for any replies!!!!
