Would there not be an enclosure to stop the splashes??
There will be a glass panel to the side up to the end of the shower tray.
Indeed, plus tanking but those adjoining walls are already tiled
If you install that shower base you are asking for trouble. The wall have already been tiled so you need to break out the bottom row of tiles. Then install shower base tight to the plasterboard. Get a Mapei shower tanking kit which includes primer, waterproof tape and membrane. At least you will have some protection from water ingress if the Silicon seal fails.Then install bottom row of tiles and get a shower enclosure fitted.
It's a bit too late for a wet room floor due to the walls being tiled first.
