Currently reading:
Floorboard Substrate Preparation
Discuss Floorboard Substrate Preparation in the Canada Tile Advice area at TilersForums.com.
I am currently redoing a bathroom. Floor is to be tiled with porcelain tiles.
The floor is 22mm wooden T & G floorboards. There are a fair amount of boards that have been previously taken up, presumably for access for electrics maintenance/ changes, etc.. Some of these boards have been badly cut for access and also had their tongues removed (I'm sure there's a joke in there somewhere). Some of the boards are also damaged or split. I can make these boards good by either reinforcing them underneath, by way of noggins between joists/ additional supports screwed to adjoining floorboards or replacing them with plywood completely.
If I repair/ replace as suggested, can I then overboard with 6mm tile backer board (Hardie, marmox, or equivalent) and then tile over? Or should I overboard first with 18mm WBP plywood, then 6mm tilebacker board, then tile, for additional structural strength.
Another option is to remove all the floorboards and replace with ply but this would be a bigger job as the floorboards span rooms outside the bathroom and the breeze block walls also sit above them. Not only this but 75% of the floorboards are in good condition.
I would appreciate your thoughts and recommendations.
Many thanks,
Daz
Homer
Leeds
Fix the floorboards (and joists if some numpty has cut half way through them to fit pipes) with a combination of screws, polyurethane glue and new pieces so that when you (lightly) jump up and down on it, it feels solid, no squeaks.
Ply is then redundant and in fact, is a bit old fashioned now.
I’d overlay with one of the newer insulated boards.
And don’t forget if you add too much height to the floor, you’ll pretty much have to add same to the rest of the house floor!
Reply to Floorboard Substrate Preparation in the Canada Tile Advice area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
We're quoting to rip up and replace a tiled floor with Limestone tiles. I'm looking for advice...
Tilers Forums on FB
