Discuss flooring adi in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
BAL Fastflex Powder & Liquid
A two part, rapid-setting, sulphate-resistant, water-resistant and frost-resistant floor tile adhesive and isolating, anti-fracture underlay, suitable for use in interior and exterior locations. Suitable for fixing ceramic floor and porcelain tiles and mosaics (including fully vitrified), dark natural stone and slate. Suitable for use on tile backer boards, glazed tiles, concrete bases, cement:sand screeds, tongue & groove floorboarding, plywood overlay, floating plywood/chipboard floors, ceramic/quarry tile/terrazzo/hard natural stone bases, vinyl tiles/sheet, mastic asphalt, steel, glass reinforced polyester (GRP), steel and galvanised steel. Conforms to BS EN 12004, Type C, Class 1F.
BAL Wide Joint Grout
A water-resistant, frost-resistant cement-based powder grout designed for grouting ceramic floor tiles, mosaics, quarries etc. Also suitable for use on walls. Not recommended for soft glazed wall tiles, or tiles with metal decor or lustre. Suitable for use in interior and exterior locations in both wet and dry conditions. Suitable for swimming pools. Conforms to BS EN 13888, Type C, Class G1.
NOTE: The physical properties of BAL WIDE JOINT GROUT can be enhanced by the addition of BAL ADMIX GT1. The polymer admixture imparts flexibility, increases adhesion and reduces the water permeability thus widening the application possibilities of the grout, with a classification of BS EN 13888, Type C, Class G2.
mixed with..............
BAL Admix GT1
A polymer additive for BAL cement-based grouts. Not for use with adhesives. The addition of BAL ADMIX GT1 greatly improves the physical properties and characteristics of the grout.
• Increased mechanical strength.
• Increased flexural strength and flexibility.
• Reduced water permeability.
GazTech
Most companies produce a flex rapid set that should set within 3 hours, I know weber does as I use it all the time and loads cheaper than BAL. Maybe 'no more ply' would be better than your 9mm ply as it's more rigid and only 6mm thick.
Cheers,
Dave
Standard single part or rapid flexi will offer no manufacturers guarantee onto 6mm cement based boards on timber. Two part is the recommended unless your boards are a minimum of 10mm thick......Gaz
Dave Carr
Never knew that Gaz, but I wouldn't know to be honest; I've never had a job fail :) not even looked into a guarantee for adhesive. Surely if there was a problem then it would be more likely the tiler at fault than the adhesive.
Cheers,
Dave
Reply to flooring adi in the British & UK Tiling Forum area at TilersForums.com
We recently completed the (rectified porcelain) floor tile installation in the bathroom and...
6K
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
Hello guys I’m looking for some advice I will be attempting to redecorate my living room which...
flooring adi
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
