Hi All,
im after some advice on flooring if i may. What i am planning on doing is removing the floorboards in a bathroom, batten between the joists and then infill with plywood. Then, install 20mm of Jackoboard (xps insulated board) over the top with flexible tile adhesive and mechanical fix. once in place i will install the UFH. The UFH is loose wire which sits in a purpose made plastic decouping mat which will be stuck down with flexible tile adhesive. i will then tile over the top.
My question is do you think the 20mm insulation board straight down on top of the joists (which is infilled with ply) will be sturdy enough for the tiles?
i decided on this approach to keep the floor buildup low, and have as much insulation as i can get away with....
another option i was thinking about was to go straight over the joists (again infilled with ply) with 'No More Ply' 6mm boards.. these, i am told are as study as 15mm ply.... then on top of the 'NMP' stick down 12.5 mm of Jackoboard....
Which option do you think would be best?
any help advice would be appreciated..
