Discuss Forming falls into wet room drain. in the Australia Tiling Forum area at TilersForums.com.
On one
What is the best way to form the falls on flat concrete floor in a wet room?
I had thought of trying to form the falls with adhesive,but this could be tricky trying to reach the far corners of the room over wet adhesive.
Is laying a preformed Wedi type shower former realistic/feasible considering the already cast in situ position of the drain?
Your thoughts Ladies and Gentlemen......
Spare Tool
That's how I'd do it and have done several wetrooms like this....2x1" wood cut with falls in, rapidset inbetween wood, thin slc then tile
This job is a new build and the whole house floor slab(with UFH)is completely flat and in 1 pour without any expansion joints!
Using sand and cement would create a very large step into the wet room I'm afraid. Even using adh or a preformed tray will create a step,but not as large.
In other words the walk in shower was an after thought ?
I'd do it with S&C myself which would create a step but then the architect should have thought of that tbh.
I wouldn't risk going down some thinner route for fear of break up.
Sounds like tray or step to me.
Diggy
Spare Tool
Diggy
What exactly is likely to break up going from say 20-30mm drop to drain using flexi rapidest n leveler, you lost me there..
Have done it this way for tiling on and vinyl floor and water goes exactly where it should...straight down the drain :thumbsup:
On one
Diggy
When I first went to look at the job I told the customer non slip vinyl would perfect for the job,even doing myself out of the tiling work. And I left the customer thinking that was what they were going to do, but they have been back on the phone wanting a price for tiling.
Spare Tool
Just out of interest,what are the gradients supposed to be? As in 1 in ? or % terms[/QUOTE
its only 2mm over a meter, so depending on the length/width of your room that's the least you can make the falls, if the job finishing up to carpet/wood I dare say you've got 30mm to play with.:thumbsup:
Reply to Forming falls into wet room drain. in the Australia Tiling Forum area at TilersForums.com
  • Sticky
Good evening to all. I’m here this evening looking for some advice if you would be so kind...
E
I have a friend that's building a wet room at the moment. He doesn't want to use a formed tray...
6K
p4ulo
Evening chaps.. Run a small company installing kitchens and bathrooms & have been asked to tile...
So attempting my first wetroom floor. Tough-X Linear wet room kit bought from the very helpful...
8K
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
