There are issues with the movement of wood no matter how well fixed - even 18mm plywood.
Then you've got a paint on tanking layer which is required to hold the weight of 1200x600x10mm tiles!
Ring BAL technical and see if they would guarantee this installation.
This is a Bal overview statement about one of their products -:
BAL Rapid-Flex Fibre Plus is a non-slip cementitious
tile adhesive for walls and floors formulated with BAL Fibre Strand Technology (FST) for improved flexibility, strength and grab. Fast-setting in three hours, it provides extended open time of 30 minutes and pot life of 60 minutes, and is formulated for easier mixing and application. A high polymer content allows for tiling direct onto plywood walls, while it is recommended for large format tiles, areas of total immersion, limited movement and heated screeds.
Their tech spec indicates
Use for
- Fixing ceramics, porcelain and vitrified tiles, mosaics, most natural stone, terrazzo, rigid foam insulating materials and brick slips in dry or wet interior and exterior environments.
- Recommended for large format wall tiles, areas of total immersion in water e.g. swimming pools and showers.
- Installations subject to limited movement and vibration.
- Heated screeds.
- Recommended for plywood walls.
