Discuss Fugi Silicon Kit in the British & UK Tiling Forum area at TilersForums.com.
brian c
is this what you are looking for?
F
faithhealer
I use this kit and quite like it. The advantage it has over the 'soapy water' method is that if you 'miss a void' or need to add a bit more silicon for whatever reason you can't because the soapy water prevents you. With this fugi kit, it's a hard plastic which does a pretty good job of scraping the excess off, and you can add more silicon if you have to. The excess can also be used again but that when it starts getting messy!
DHTiling
I think the karl dahm kit is nice....
Silicon Set
http://www.tradetiler.com/acatalog/Silicon-set.jpg
Silicon smoothing rubber tools for all joint shapes
For creating perfect joints fast. Made from a soft rubber like material
An exceptional and unique set of tools of professional results
Set consists of:-
4 mm radius and 45 degree angle tool
7 mm radius and 45 degree angle tool
10 mm radius and 45 degree angle tool
storage case included
First apply your Silicon in the normal way. Spray the whole area with a strong soapy solution (i.e. washing up liquid and water, (spray bottle available below) then use these tools to even up and form a perfect joint in seconds! Keeps Silicon off your hands
weight 110g
Click for bigger picture
Price: £8.97 £10.32 Including VAT at 15%
TradeTiler.Ltd Siliconing - sealers/primers
Woody123
Dave i have looked at that set and i have thought about investing in that one but i kind of like the fact you don't have to use washing up liquid to get your neat finish as faitheealer points out if you for whatever reason have a void in the Silicon you can add extra Silicon to it.....
Brian C sorry i can't see what your posting as it is just a cross and nothing happens when i click it....
Reply to Fugi Silicon Kit in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
We recently completed the (rectified porcelain) floor tile installation in the bathroom and...
Fugi Silicon Kit
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
