General advice on adhesive and grout
Thank you for looking.
I am about to tile the floors and walls of a small bathroom. I am using 450mm x 450mm ceramic tiles. The floor will have a heat mat on hardiebacker. I know I need a flexible adhesive, the choice is bewildering. Can anybody give advice onto the best make, Bal rapid fibre flex in white? ( tiles are white marble effect ). Also looking at grouting floor with light grey grout again is Bal the best choice of make - keep it all Bal?
Any advice gratefully received - don't mind mixing different makes of adhesive or grout to get the best results?
Hi,
It is bewildering the amount of choice and every professional tiler has their own preference. I’m assuming you’re not a professional to you’ll want to go for a standard setting adhesive. My personal preference is tilemaster then after that I use Ultra. The Tilemaster Grout 3000 is really easy to work with and doesn’t go off too fast like other brands. A couple of links below to the products I use these guys also do next day delivery before 10am and they’re really well priced.
Tilemaster Setaflex White Adhesive
Light Grey Grout 3000
Toby11,
Bespoke Tiling,
Toby11,
Bespoke Tiling,
