Hi all.
My project is to lay approx 6m2 of porcelain tiles in a dressing room & 4m2 in the wet room the floor is 25mm ply screwed & glued to the joist with marmox tray at ffh.
My plan is to have electric underfloor cable.
My first question is:
I have used 12mm cement boards to the walls ready for tiling & have 6mm cement boards for the floor will these provide a good enough insulation for the UFH cable would anyone know?
And secondly:
I am planning to put oak floor plate around the dressing room wall edge and this will provide the threshold for the doorways & to tile up against 20mm of thickness I'm thinking of using a coupling membrane,then the cement board,then the cable for the UFH ,slc if I need to bump the height up then tile to the top of this to come up to my FFH.
Does this sound correct?
I would appreciate comments and advice,thanks in advance.
Kelvin.
And secondly:
Kelvin.
