bureaucrazy
- 178
I have to tile a bathroom with 300*600*9 Porcelain tiles. They are the Zafira tiles from B&Q. They are not polished but are smooth and have a sheen to them and there is a cloudy effect printed on them. They do not seem to absorb water drops but the packaging says they are unsuitable for outdoor use presumably due to risk of absorbtion and frost damage. They were very very cheap so may not be of the highest grade.
1. I am really confused as to whether they need to be sealed or not as I have read lots of horror stories about staining of unsealed tiles. How do I tell?
2. I am new to this so I am scared that when I lay them the adhesive will ooze up between the joints leaving no room for grout. Is there an easy way to avoid this so I dont have to rake it out?
3. I am worrried that the adhesive with get all over the surface of the tiles and ruin them. Should I use masking tape or is there a spray or something I can protect them with?
4. If I do get adhesive on the surface, what is the best way to remove it without loads of water running behind the tiles and diluting the adhesive?
