Discuss Genesis Leveling System in the Australia Tiling Forum area at TilersForums.com.
JCT
Hi
Has anyone used this? I took delivery of this yesterday from protiler. I was expecting the straps to have a flat base like they have in the promo video but they are curved. The curve is approx 10mm which I think is going to cause me problems. I just don't see how I can insert them on tiles that have been laid where I'm fitting the next tile. Surely it would pull the tile up. The curve flattens when the caps are on and pulled tight but I'm struggling to see how they can work unless I have quite a thick bed of adhesive.
Anyone offer any advice? I'm used to using flat bases which can be inserted in tiles where the next tile isn't going to be immediately fitted.
White Room
Not yet, will give them a call tomorrow.
I had some from protiler and the same problem as you and called them, they said that Genesis had stopped making them with flat bottoms so why show a picture of them on the container they come in, Protiler was no help at all:mad:
N&C sell them with flat bottoms which are the Genesis type.
JCT
What's N&C?
L
LM
I use the Genesis system, you can order either 'curved base' or ' flat base'
As regards the thickness of the clip base being too thick, who honestly would lay a tile that's large enough to require a levelling system with anything other than a 12 mm notch minimum, therefore the thickness of the levelling base isn't an issue.
I've been using the Genesis system because it does the job , but it used to be priced right, however I've recently been hit with a 50% price increase so I think I'm going to defer to the Ramondi system like everyone else on here does, and see how that compares.
White Room
Did find there expensive and like yourself the Raimondi ones but recently sent for some cheaper versions from Italy.
Reply to Genesis Leveling System in the Australia Tiling Forum area at TilersForums.com
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
  • Sticky
5K
Matthew7
Hi guys, had some great advice here before so thought I would ask here for advice again...
JCT
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
