Discuss Genesis Leveling System in the Australia Tiling Forum area at TilersForums.com.
Tile Shop
So how come you get flat bases but protilers get the curved ones ?
Old stock maybe? Not sure. Or maybe i was just lucky. I'll give genesis a call tomorrow to see what the crack is.
I know they only have one code for the clips so maybe theere was a design change following critisism of the rounded base.
I'm just guessing but I'll find out and let you know.
White Room
When I called Protilers they said to me that was a design change but I know I can get them from N&C with flat bases but not at there prices.
White Room
Tile Shop
took a little while to get used to the pliers, I snapped maybe 4 of the bases off before I realised that you slide the pliers sideways to release.......dooh!
Similar issue when i tried to tighten them up. I'm no expert on levelling systems, but i gave it a go at work. The white straps snapped very easily when tightening up and trying to bring the tiles level. I'd imagine on larger format tiles, the suction from the adhesive would make this system less effective and more difficult to straighten out? And, are the straps very weak or am i being too heavy handed with the pliers?
White Room
I found them ok, after a few you get the feeling of how much pressure is needed but only used on wall tiles though.
They're not really designed to 'straighten out' tiles!
They wouldn't snap so easily if they were.
They're simply to hold the tile in place while the adhesive sets,
to prevent any kind of shrinkage effecting the finish.
You're obviously way too heavy handed! Hahahaha
Wishiwasatoptiler
1,118
Northeast
Used some on the last large format tile job. Loved them. Had non snap and brought any small descrepencies out.
Reply to Genesis Leveling System in the Australia Tiling Forum area at TilersForums.com
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
  • Sticky
5K
Matthew7
Hi guys, had some great advice here before so thought I would ask here for advice again...
JCT
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
