Discuss GGBS in Cement Based Tiles Adhesives? in the UK Tiling Forum area at TilersForums.com.
Johnerr
Hi,
I'm interested in the problem of ettringite formation on Calcium Sulphate floor screeds when in contact with cement based tile adhesives. I work for a GGBS, Ground Granulate Blastfurnace Slag, producer in Ireland and our product works exceptionally well in mitigating sulphate attack (ettringite formation being one) in concrete. I'm wondering has anybody come across GGBS in cement based tile adhesives, I believe our product could work very well in this area any may possibly remove the need for a sealer/primer when using calcium sulphate floor screeds and cement based tile adhesives and possibly open up the use of calcium sulphate screeds in wet rooms.
Regards,
John
Ajax123
1,213
Lincolnshire
Hi John
One of the issues I have come across when GGBS and PFA are used in contact with Calcium Sulphate is polysulphide attack which disrupts the screed expansively and very aggressively. It is quite a rare reaction and where I have seen it it has been associated with concrete blocks in block and beam floor systems where there is no divorcement of the screed from the blocks.
If you are serious about looking at this PM me and I will be abe to discuss it with you. I was on a site today where there has been an issue with the adhesive and I felt that there might have been GGBS in the adhesive but I was unable to ascertain the brand or manufacturer.
Reply to GGBS in Cement Based Tiles Adhesives? in the UK Tiling Forum area at TilersForums.com
    • Friendly
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
I’m halfway through tiling a shower cubicle at home. First time doing any tiling. I’ve used...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
