Discuss Glass and stone mosaic adhesive? in the Canada Tile Advice area at TilersForums.com.
59peejay
Have about 1.5m square of mosaics to fix for kitchen splashback and after reading advice here was all set for a trip to topps for some Bal mosaic fix,but then i read a post by David Howe dated nov 2007 about glass wall tiles in which he states painted back glass should be fixed with apoxy or mirror adhesive?,now that's thrown me a curve ball!.
My mosaics are 15x50 on a 300x300 mesh and are a glass and stone mix about 20% stone the rest glass with a painted back some kind of shiny gloss.What is the best product for thes please?.Fixing will either be primered plaster skim or some cementious addy if i need to build it out,thanks.
For interest Bal spec for the mosaic fix says..not suitable for glass/metal tiles with water sensitive coating on back.
DHTiling
Always if in doubt to the backing then contact tile manufacturer for fixing instructions .. i will say though , that delicate glass tiles do normally have a slip/instruction leaflet in the packing to say they need to be epoxy fixed etc ... this leafelt also dictates if they can be used in areas of high heat , like behind gas hobs etc.
But with them being a stone mix with glass , then i would say that cementious adhesive will be fine.
59peejay
They are a Chinese made stuff from BnQ all it says on card is that the stone pieces need sealing before and after grouting.
Also i have tried placing various things under the mosaics including a steel rule and can't see any shadows,so will i be ok with pressing them into my lines left by the mosaic trowel without flattening them off?.Link to tile Colours Grey Linear Stone And Glass Mosiac Wall Tile, 300×300mm, 5397007009330
DHTiling
I have fixed them ... they are fine... relax and enjoy..
Reply to Glass and stone mosaic adhesive? in the Canada Tile Advice area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hello to the forum. I am a carpenter and have undertaken tiling in my own house. I completed the...
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
