H
herny80
I am having a problem with glass tiles they are 1m long by approx 6inch wide and they are running along the back of the kitchen work top. They have a self adhiesive back on them, the problem I have is that i need to cut a notch out of the tile to fit flush to a plug socket, But when i use my wet cutter the back of the tile gets cut further than the top just like it would with a ceramic tile but obviously with the glass you can see the cut as the colouring for the glass is given by a coating on the back which is being cut away.
Also I Have to cut a 10mm sliver off the bottom of a 900 x 900 glass tile to fit at the back of the oven and i dont have a way of scoring it as my tile cutter only does up to 600mm. is there a easy cost effective way to solve this.
any tips appreciated thanks
