Discuss glass tiles in the British & UK Tiling Forum area at TilersForums.com.
how do I cut glass tiles,they are 95 x95 5mm in size
thanks for the advice,but tried scribing first and when tried to cut tile it kept on breaking along the scribed edge
imo an 8mm piece is to small for any scribe and break machine although some one will prop prove me wroung lolIwas cutting an 8mm wide cut,I am using a hand scorer and dry wheel disc cutter
:welcome:To the Tilrs Forum.
As peckers really.
I tend to use a hand held set of Oporto cutters - they have a glass cutting wheel and snapping action in one.
Smaller cuts on wet machine.
Make sure you use a 'white' adhesive as off white/cream can affect the colour of the glass tile.
Non scratch grout to finish.
If the cut edge chips the white backing colour of the tile - you can touch up with 'tipex'.
Wear goggles!
Reply to glass tiles in the British & UK Tiling Forum area at TilersForums.com
