Discuss Gres porcelainco in the Canada Tile Advice area at TilersForums.com.
White Room
[h=3]Grès Porcelain stoneware is a ceramic with a compact, hard, coloured and non-porous body. The word “grès” means that the ceramic body of the tile is extremely vitrified, that is to say compact, hence the exceptional great resistance.
The result is a lean clay body, little refractory, fired in a kiln (at 1200-1400 C°) until it reaches a non-porous vitrification and a complete water-proofing.[/h]
asif
Thanks. Is this same as vitrified tiles?Is there any advantage over normal ceramic? Is the normal tiling charge more/less than ceramic? apologies for lots of questions :-(
Reply to Gres porcelainco in the Canada Tile Advice area at TilersForums.com
What would you guys do with the walls to prep for fitting 1200mm x 600mm Onice Verde (Porcelain)...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
Hi, can I use BAL Quickset Render to level and area between Hardiebacker and drywall then cover...
Tilers Forums on FB
