Discuss grinding terracotta tiles to even surface in the UK Tiling Forum area at TilersForums.com.
L
Lauri Marder
hi- new member here-
We are dealing with a vast expanse of installed kiln-dried terracotta tiles, which are not laid evenly enough, and we wish to take off the high points and smooth the surface. Can someone recommend a method? Would a wet- polisher work? What type of disks could be used? Thanks!
L
Lauri Marder
No, these are newly laid, in Venezuela. A huge expanse- they are not finished or sealed, and they will be eventually sealed and waxed (in the usual way, with oil and then a wax). The tiles have a very uniform somewhat pitted surface, completely flat, like bread slices. We use the floor for various activities, and the ones that stick up are a problem. There are also some which are laid higher than others, and it would be good to level them off. I know it's not the usual thing to do this, but wonder if it could be done, without for instance damaging them. A lack of uniformity in colour or texture might not be a problem since we are talking about various shadings anyway, and such a big expanse- thousands and thousands of tiles.
U
user123
Sorry, I can't post a photo - don't really know how
Ok Lauri,
you can't post an image via the quick reply, but can you see the 'Post Reply' button on the bottom left of the page after the last post? If you click on that, you have more options for the message, one being the little paperclip symbol for attachments, click on that and a new small window opens where you can choose to add an url, which is unlikely you'll want, but underneath that you can browse in your PC pics and choose from there and then insert by double clicking. The text will turn into the picture once submitted.
Go and try?
L
Lauri Marder
trying again
U
user123
Nope, nothing there...try again? Otherwise, you can email me and send me yor pics (via my website - see 'view my homepage') underneath my name/avatar) and I put them up for you, are they in jpg or gif?
But grinding down terracotta sounds really dodgy to me... I would do as pjc said and have them taken up and replaced...
Reply to grinding terracotta tiles to even surface in the UK Tiling Forum area at TilersForums.com
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
I am installing 6x24" (152mm x 610mm) wood look porcelain tile in an approx 200 sq. ft. (6096mm)...
DIYish
Some info you pro tilers might find useful... TTA urges extra care on tiling with mesh-backed...
Flintstone
F
11K
Rizzle from the Portizzle
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
