Discuss Grout gap in the UK Tiling Forum area at TilersForums.com.
What is the best looking gap size for grouting for a 600x600 Polished porcelaine tile. It's for a kitchen floor about 25 square meters.
movement is always a possibility john.........What is the substrate? You can usually go tighter on a solid floor where movement is not an issue but 3mm on timber prepared.
The Eagle porcelain are usually pretty good quality but surface preparation/flatness will be an important factor.
I mostly use 3 on floor and wall. I like to keep things the same, just seems neater.
If doing 10x10s for kitchen splash then I use 1.5 joint.
I done my ex girl friends bathroom 600x300 polished porcs with a 1mm joint, looked really good, + only used half bag of adhesive for the whole room
well spotted john! LolI'm surprised they're still on the wall. Did you use the motorway sandwich method, put the addy on and then wipe it off? :smilewinkgrin: I'm sure you mean half a bag of grout Charlie
I'll be the odd one out then. I prefer 5mm. Each to there own though. Generally, I'll give the custard the option & let them pick. They ate the one that's got to live with it, not me!
Sent from my iPhone using Tapatalk - Couple a' Tools
Reply to Grout gap in the UK Tiling Forum area at TilersForums.com
