Discuss grout line thickness? in the Canada Tile Advice area at TilersForums.com.
There is no right, probably just a wrong grout gap. Would not recommend going below 3mm - but I have seen slate laid at 2 and 1mm. The uncalibrated refers to differing thickness of slate - mostly they are cut fairly consistently width/length. However you must check first, then you may discover width/length variations of perhaps 2 or 3mm - and in order to keep the pattern uniform you may need a 7 or 8mm gap. Some of the bigger slabs look better with 10mm gap. Then there is the customer view - offer a 5mm gap and most accept with floors.
thanks... they are uniform size arnt they? is it not just the actual thickness of the tile?
Mr 't' - I'am not sure if an eye joint has a definitive measurement value as in 5/6mm or similar, or indeed if there is a relevant British Standard for Uncalibrated slate, however it is often considered that with tiles of varying sizes a regular joint sizes formed by using a consistent thickness of spacer peg will not provide a straight line in the layout.
Therefore by using a chalk line and keeping it between the tiles with equal distance either side ( judged by using 1 eye open and the other closed - eye line) then this will provide the required joint size. Hope this helps.
take some pics and post up when ya done mateyThankyou Timeless John. much appreciated. Im prepping and setting out it tomorrow so will nip back on with an update
Reply to grout line thickness? in the Canada Tile Advice area at TilersForums.com
