Discuss grout sealer in the UK Tiling Forum area at TilersForums.com.
DHTiling
Try this 1 from LTP..
LTP Grout & Tile Protector
Description: A colourless barrier that helps to protect porous wall and floor grout joints from penetration by water,dirt,oil,grease and limescale, making treated surfaces easier to keep clean. Ideal for use in wet rooms and shower enclosures. Used as a top coat this product is an easy way to further protect natural stone and all other types of masonry surface.
Tips:
Technical Data Sheet (PDF)
Reply to grout sealer in the UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
Hi any info on get rid of epoxy grout haze on natural stone would be much appreciated. I’ve used...
Hi all, We employed a tiler to lay some rectified wood effect planks in a herringbone pattern…...
Hi any advice on what would go with what. I've layed off white tiles on floor with grey...
grout sealer
