Not long ago I had the existing water damaged downstairs bathroom floor replaced with a whole new chipboard floating floor – this was before considering tiling, so I realise it would have been better to fix the floor but too late now.
Having later decided to tile, the tile supplier suggested covering with 6mm No More Ply, priming it and using Ultra Tile Fix ProFlex SPES S1. The grout used was Mapei UltraColor-Plus to match what was used with the wall tiles. The whole floor has not been tiled - just the small visible area - 6 x 4 330mm square tiles.
The floor tiles have only been down for 5 weeks and already the grout is starting to crack and I can just about see deflection up and down of the tiles!
Is this simply because of the floating floor, or the wrong adhesive or the wrong grout – a bit of all perhaps?
What do you suggest as a way forward? A whole new floor would mean ripping out bath and fitted furniture etc!
