Grouting Mosaics with Cavities
If you used a larger notched trowel the addy may squeeze through and cleaning mosaic joints is no fun, a 4mm maybe better
Once you have fixed a row of mosaics, I use my rubber grout float and gently push/run this over the mosaics to get them flat.
An off cut of tile works well also.
I would go for the 4mm trowel, it will help with the thickness difference. More important, it will give you better coverage on mosaic.:thumbsup:
TheRealRobG,
The Legend; Phil Hobson RIP,
TheRealRobG,
