grouting slate
Z
zohar1
Im due to lay a slate floor and was wondering what was the best way to groat after sealing. should i groat and clean with washboy as normal or use a groat gun. Has anyone ever used a groat gun and if so are they good or are they time consuming. thanks.
Re: groating slate
I always grout slate using sand and cement. Dry mix the sand and cement (Kiln Dried Sand is the best) I part cement to 4 parts sand dry mix thoroughly then add water slowly until you get a crumble type mixture. Sweep into the grout joints then draw a piece of appropriate size rubber hose or wood dowelling along the grout joints. This draws the water to the surface and Hey Presto. No Mess and its quick:thumbsup:
Kev
Re: groating slate
Kev
Great post Kev, something else I've learned now.:thumbsup:
Grumpy
Re: groating slate
Am assuming its not honed or polished slate here :
Slate doesnt absorb from above as its not formed the same way as other stone. If you grout it as normal using a sand based grout, allow the grout to just dry on the surface of the tile then wipe off. Repeat the wiping process a couple of times keeping your sponge clean
In a couple of days when fully dry buff off the dust and apply a coat of Lithofin slate seal. This particular sealer will leave a sheen on the tiles, the sheen can be increased the more coats you apply. The beauty IMHO of this sealer is if you have missed any grout or have clouding it darkens it up so it can become unnoticable.
tiler
Re: groating slate
Kev
I'm assuming this is no good if using flexi addy and require a flexi grout too?
Re: groating slate
tiler
I love lithofin slate seal, a top product.
Re: groating slate
Kev
I would really recommend trying this method as using normal grout because it is so fine is a nightmare. The stuff gets in all the riven edges and is a complete pain to clean off even with chemical scrubs.
Why would you be using chemical scrubs if you work the process why would you need to strip, clean, acid wash.
It is the easiest stone on the market and doesnt absorb if the tiler leaves it dirty then it is a process problem surely.
Scrubbing cleaning acid washing is a cure not the answer !!
tiler
grouting slate
zohar1,
Ric,
zohar1,
Ric,
