Discuss grouting techniques in the Canada Tile Advice area at TilersForums.com.
stephenoneill
for all my large floors i grout as follows;mix grout to a liquidy state apply to floor with squeegee ;then apply grout straight from the bag on the floor leave settle 5minutes then aggressivly push key in the grout with my squeegee:this technique has many advantages 1 the grout is perfectly level with the tile;no hollow groove between the tiles 2 the tiles are completley cleaned dry so when i go to clean with the sponge its quicker and easier to finish;always use this technique and have perfectly grouted floors; anybody got some other techniques to share:hurray:
DHTiling
Ruff *** git .... is your
out back :):):)
The D
That was a method we used years a go before pre mixed grout was so popular it is a fantastic method when using 3&1 sand and cement for your grout but I would not do that with pre mixed grouts
charlie1
Hi steph, Saw tommy walsh do that when pointing a patio once, ...but he not a tiler!
I mix batch, grout joints (prob for arround 10 mins)... so 1 or 2 walls depending bla bla, then wash off... but at the end, i change all the water in my wash boy and give 1 more final wipe... then as drying i very lightly with small sponge give each joint 1 very light pass just to ensure no water is sitting on top of joint
+ always use mapei ...like always!
charlie1
I've had one or two bad experiences with grouting so i tend to stick as close to guidelines as i can. Oh,i have learned many a grouting lesson. Never use granfix and always make sure your floor is dry before grouting. Once i gave my floor a prewash but saturated the floor, by the end of the grout, i was grouting with paint, lesson learned, thankfully it turned out ok.
Reply to grouting techniques in the Canada Tile Advice area at TilersForums.com
So... have a problem maybe some of you guys (and girls) might be able to help with. Laid a new...
19K
We have just finished a 23m floor done in 300x300 grey rocktop porcelain from Johnsons Kerastar...
5K
View: https://www.youtube.com/watch?v=PQ-MXRJTp6s Raimondi BERTA Grout Washing Machine...
6K
Italy
I
grouting techniques
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
